Old 07-12-2008, 08:25 PM
Jim Abner Jim Abner is offline
1989 F150
I have a 1989 F150 4x4 that died and wont start. I pulled a spark plug and got no spark. I have changed ignition switch,coil and EGR relay could it be in the ditriburtor. Please help
Old 07-12-2008, 09:36 PM
vgames33 vgames33 is offline
Re: 1989 F150
http://arrc.epnet.com.oh0049.oplin.o...ain.autorefctr
Let me know if the link doesn't work. I'm trying to direct link to something that you normally need to log in for. If it asks for a card number, just enter 123456789. There is a section on testing the ignition system for your truck.
Old 07-13-2008, 12:27 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1989 F150
If you have an Autozone or similar nearby, you can probably take your ignition module there and have them bench test it.
-Rod
Old 07-14-2008, 08:07 AM
Re: 1989 F150
This site sends me to ohio libary
Old 07-14-2008, 09:18 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 1989 F150
-Rod
I agree. Ford modules do not last forever. Unlike other ignition parts failures, the module either works perfectly or not at all, so it gives you no warning of impending failure.
Especially if the original is still in the vehicle, I would strongly suspect it's gone bad.
Old 07-15-2008, 09:03 PM
Re: 1989 F150
where is ignition module located
Old 07-16-2008, 08:49 AM
MagicRat's Avatar
Re: 1989 F150
I believe it is located on the side of the distributor, (but I am not absolutely sure on your model). It should have 3 wires hanging off it.
You may need a 4.5 mm socket to remove it, which is an unusual size, but a good parts store should be able to supply you with one.
