Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-12-2008, 06:46 PM
cutlasscrazy cutlasscrazy is offline
electric Fan
I needs new fans for my 98 cutlass...they are .electric..I want to replace the whole dag on thing ...harness and all. I am looking for a high performance fan. So I need to where I can get one that will fit my car....any suggestions?
by the way in my there are two fan one to cool the car and one that only works when the a/c come on is there anyway safe way get both of them to come on at the same time all the time using the a/c or not using it?
Old 07-13-2008, 11:08 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: electric Fan
Which engine did you have ??
The one should only run when the temps get up to around 220 deg then at 230ish they both come on. Ir when the AC is on they both should run.
If one constantly runs then you have other problems, could be a relay or the temp sending unit isnt functioning properly.
Their's many palces to get after market fans.
Best way to find them is measure your old units then start searching the web, ebay, etc etc.
They do need to be the same voltage(s) and amps, other wise you'll need to upgrade your wiring and relays.
1999 Grand Am SS 3.4 OHV
Old 07-13-2008, 12:39 PM
Re: electric Fan
i have the 3100 V6...but i have looked all around the web.....im geting mostly universel fans..but i dont know if they will work or not...
