Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 07-11-2008, 07:45 PM
anointd anointd is offline
Code p0741 Transmission will not shift past 2 gear
01 Yukon xl 4L60E. Code p0741. Transmission will not shift past 2 gear. I have changed the TCC and the TCC width modulation valve. Tranny still does the same thing. Any suggestions.
Old 08-29-2008, 07:07 AM
DangerDude DangerDude is offline
Re: Code p0741 Transmission will not shift past 2 gear
I just had this same problem with my 1992 C2500 with the 4L80E tranny. turned out to be the Vehicle Speed Sensor (VSS) cost me $27 dollars at the dealer. Fixed it ! (whew)
DangerDude
Old 08-29-2008, 07:46 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Clear code with a scanner and recheck.
Code P0741 is a tcc code.
Unless transmissiomn has went to failsafe mode 741 should not keep it from shifting past 2 nd gear.
Get it on a good transmission capable scanner and check it out.
There should be more codes someplace.
Post back what it does after code clear and other codes.
MT
MT
Old 08-29-2008, 08:10 AM
MT-2500's Avatar
AF - Advisor
Also check transmission fuse and power and wiring to computer.
MT
MT
