Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 07-11-2008, 11:20 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Question Cause of Transfer Case Failure
Hey guys, I'm not new to automotive forums, but I am new to the Sonoma section. I'm looking to buy a '00-'03 Chevy S-10 or GMC Sonoma ZR2 but I keep hearing a lot about how common it is to have the transfer case go on people. Does anyone know what causes such a common failure? Is it strictly the transfer cases with the available auto 4x4 or is it all transfer cases prone to self destruction? I appreciate any advice or information. Thanks in advance!!
Old 07-13-2008, 03:56 PM
wafrederick wafrederick is offline
Banned
Re: Cause of Transfer Case Failure
I never heard of that happening.One failure is never checking it during an oil change,fluid level checks are a must during an oil change and most oil change places skip this step.1999 and up GM transfer cases use a special fluid,Auto Trac II from the dealer only and not ATF.
Old 07-17-2008, 09:29 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The earlier versions of the Jimmy/Sonoma with the electronic shift switch had issues with the encoder motor and controller to a small extent, but most of the time it was due to the vacuum-operated front differential lock-up...usually a torn actuator or bad relay. I wouldn't worry about it if the truck has been taken care of. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
