Hi, im pretty new to rx-7's and rotary engines but please forgive my little knowledge when i ask this question. Ive heard alot of older gen. rx-7s being swapped with a v-8. I was also wondering if you could swap the FD with a v-8 or v-6? Im talking about a realistic application that would be relatively cheap to perform. From what I hear, it costs quite a bit to maintain the rotary engine. I don't want to enrage all of you ppl that are appalled at the idea of having pistons in an rx-7 but I just want to know if its realistically possible. And if it is, what type of motor would be best and how much I would be spending if I were to swap? Thanks...
hmm...
any comments? cmon guys...
im not an expert but you could put any engine in any car that had a big enough engine compartment its just a matter of money. if you dont want to spend too much money your best bet would be a v6. you could probably get one in there without too much trouble. i have an 83 rx7 and the engine compartment is pretty big. also since they are rear wheel drive to make it easier you could get a v6 from a RWD car. im not sure tho if it would be easier to modify the engine to fit the tranny or buy the engine and tranny and modify the trans to fit the propeller shaft. how about an older supra engine - that would be awesome. again im not an expert you should probably get a second opinion in case i said something wrong.
Civic:selling the D16Z6 getting ready for a B16 turbo ![]() 240Z:was thinking about a VG30DETT but am now looking at a V8 |
eh, pisst-on engines inside of 7's are looked down upon. the 7 is a car you have to love to keep. You culd get a 3 rotor engine, or mod your 13b.
although i despise the idea of a v-8 in an rx-7, it can be done relatively inexpensively, depending on if you're doing it yourself or having someone else do it. first of all, the total weight difference is not that much, but the center of gravity is still favorable with a rotary. also, about the 20b swap...that is in a whole nother league of engine swaps. this swap would cost AT LEAST $30,000 when all is said and done. if you don't want to deal with the problems of the rotary, and it's too hard for you to get to know your car and properly care for it, then don't get one. it's really not a problem unless you let it become one. you just have to be knowledgeable about the car, and you should have minimal problems.
IVE SEEN IT DONE IN AN ARTICLE AND IT WAS CALLED THE SUPRA 7
SO I FEEL YOUR BEST BET IS TO PUT A 1993 SUPRA TWIN TURBO MOTOR, CUZ IF YOUR GOING TO DO THAT TO A 7 MINE AS WELL BE ANOTHER TWIN TURBO ENGINE THAT IS ALSO REAR WHEEL DRIVE..
david |
not 30k rxtacy, more like 15k for a good stock install, +5k for mods.
I've heard of an rx-7 with a 2JZ engine, but it was not cheap.
No way would a 20b cost at least 30k... I could build a 26b for about 20k... |
i know a 20b does not cost $30,000. the money is mostly spent on labor and miscellaneous parts. it takes a lot of modification to make this conversion work. if you're going to do all of the work yourself, then it definately wont be that expensive, but how many people can honestly say they are capable of performing this conversion w/o errors on a car which errors are deadly.
you think you can build a 4 rotor dayna? all power to ya if you can, but i doubt it would happen. first problem: you'll have to perfectly fabricate the eccentric shaft unless you can find one from a 26a (probably impossible). then you will have to customize an intake manifold. and after that and a lot of other stuff, you'll still have to find a way to make the transmission fit, which will most likely involve some minor modifications to the chassis of the car. i could go on and on but you get my point. |
what the hell is a 26A???
Those 26B's that are two 13B's joined have alot of probs with the eccentric shaft, or so I've been told, not that I've seen one. I reckon u could get a 20B in an RX7 for around $15-20K AUS, so around $10K US. |
26a and 26b are both 4 rotor engines. a designates two side seals and b designates one side seal. it's a complicated system because the 12a would be a 12b if it followed those rules. so 26a and 26b are pretty much the same. i assume that if you built a 4 rotor, it would technically be a 26b. but i think (i may be wrong) that the original name of the engine that powered the 787b was "r26a."
The intake will be cake work. Make 4 p-port flanges... bolt them to the rotor housings... measure... remove and start welding the flanges to fabricated plenums... This Frankenstein is not going into an RX- chassis of any kind and will be connected to a T-5 transmission via an adaptor kit. I've been building engines for a while... so if you want to go on and on, it is fine, but I am sure it is something that I have already solved. I am not being repugnant in any regard, but your line questioning my abilities certainly does so. I guess my point is, do your best to help support others not tear them down, you may not know who you are talking to or who else is reading.. |
i wasn't tryin to tear anyone down. ya just gotta understand that there are maybe a handful of people who would actually attempt to put a 4 rotor into an rx-7, so i'm entitled to my doubts.
20B or not
okay, im going to assume that many of you might not have to much hands on experience with rotaries because thats how it sounds, but thats fine, some ppl have more experience than others and thats how we learn this stuff.
First of all where in the world did this price of $30,000 for a 3 rotor setup come from, even $15,000 is to say the least, pretty out there. I live in Los Angeles, Ca and i get my motors direct from Japan through friends for much, much, much less cost, and we're talking complete motor, wire harness, and ecu, usually with the transmission. On top of that i get great shipping rates from a local freight company, i regularly ship out 12a and 13b motors as far as New York for much less than most guys can ship one interstate. For the most part the average mechanically inclined person with basic knowledge can do this in their back yard given they have the right parts that is. of course you need different motor mounts, driveshaft, relocate the i/c, radiator and such. It's not, in my opinion, really worth putting in a 3 rotor unless u really want to be able to say u have a 3 rotor. it's much easier and cheaper to rebuild a 3rd gen motor with hi performance parts, upgraded seals, hi rpm bearings, and a machined streetport. i stress a machined streetport because they are much more efficient and accurate than those made by using a dremel or die grinder. out here we do a 3rd gen build up that gives us 330 horsepower to the wheels, thats with stock setup, stock exhaust, injectors, and running only 8pounds of boost. Thats rite 8 pounds of boost, 2pounds less than stock, and making 330 horses. if you want to run it at the track you can turn it up to 16 pounds and push over 500 horses on the stock turbos. we have no problems with these motors as daily drivers and have a list of about 30 refferences that we've done these build ups for with no problems and great feedback over the past 2 years. i am always putting together cars and sending out motors. if anyone needs help let me know. E-mail at [email protected] |
