Old 07-10-2008, 10:17 PM
Cruize Cruize is offline
Ignition Switch repairable?
My 95 Blazer will not start. It cranks, but won't start. No fuel pump or idiot lights when I turn the key to the "on" position either. One time I did get the idiot lights and then it started. From what I've read on past threads, I am assuming the ignition switch is the culprit.
Is it possible to repair the ignition switch rather than buying a new one?
Thanks in advance.
Cruize
1992 Ford Escort GT, 5-speed - Now with an unlimited slip clutch! :sarcasm1:
1995 Blazer LS, 4x4, 4 door
1996 Pontiac Grand Am GT, 5-speed
1997 Suzuki DR650 ~54 mpg
Old 07-11-2008, 09:09 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Ignition Switch repairable?
May or may not be a bad switch.
Get a good wiring diagram and check for 12 volt power to it and out of it.
Make sure battery and cables and fuses and fuse links and wiring is good.
Check the plug wiring on electrical switch.
Not the key part.
If electrical switch is bad the best repair is to replace it.
Good luck
MT
MT
