Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 07-10-2008, 09:10 PM
pvisser pvisser is offline
Send a message via MSN to pvisser
Unhappy AC Rattler
I have a 99 Montana with a rattler in the AC..
AC works great, however, when I turn it off the compressor rattles, actually sounds like steel scraping steel.
Is there a way to rebuild the clutch in the AC without removing it? Or is it repairable at all?
Thanks
Paul
Old 07-21-2008, 01:48 PM
Re: AC Rattler
Anybody have a clue of what I am talking about?
Old 07-23-2008, 07:59 PM
ecartman ecartman is offline
Re: AC Rattler
I have seen this problem many times on various GM vehicles especially ones with V5 compressors. I believe you can buy A/C hub & clutch separately but I can't recall if the compressor needs to be removed on this particular vehicle to replace it. You will need an A/C compressor puller/installer tool to properly remove and install the hub without damaging it. Another option is to go with new or reman compressor (preferably AC Delco) but this could get pretty expensive. Question, have you ever had to replace the A/C condenser on your Montana?
Old 07-23-2008, 08:35 PM
brcidd's Avatar
brcidd brcidd is offline
Re: AC Rattler
Yes it is V-5 classic clutch drive drag-- need to borrow clutch remover from autozine and pull clutxh out to .020" air gap-- very very common on v-5 compressors
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-24-2008, 09:06 PM
Re: AC Rattler
Nope. It's always worked great.
So what r u saying? Just increase the gap to .020" and it all better?
Old 07-24-2008, 09:43 PM
brcidd's Avatar
Re: AC Rattler
yes- I do them in the parking lot at work- anyone who has a V-5 compressor will need it done sooner or later. Replacing the compressor fixes it also- but who need to pay $600 for a free fix?
'99 GMC Yukon
Old 07-25-2008, 10:16 PM
rockwood84 rockwood84 is offline
Re: AC Rattler
yeah the clutch is too close to the pulley and is still hitting after you turn a/c off. increasing the gap on the clutch plate will solve this. some autostores such as autozone will loan the clutch tool set and it only takes ten minutes to get a twenty mill gap between the clutch plate and pulley.you can do this without removing the compressor.
