Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 07-10-2008, 06:19 PM
dpsawill dpsawill is offline
94 LaBaron GTC 3lt
Tach, interior lights, radio all quit working. Door locks won't work if engine is off. Worked on and off for a short while, I don't think it's a fuse.
Old 07-25-2008, 11:24 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: 94 LaBaron GTC 3lt
Have you checked the battery and charging system?
Old 07-30-2008, 12:31 PM
madmanmapper's Avatar
madmanmapper madmanmapper is offline
Check all your fuses anyway... expecially the IOD fuse, which is in the fusebox under the hood. Some Chryslers have the IOD fuse and some don't. BTW hope you know that the power lock wont work with the key in the ignition and the driver door open.
Old 07-30-2008, 12:38 PM
Polygon's Avatar
The Red Baron
Is that a feature that they integrated in later models? My 89' GTC will power lock the doors regardless of the key being in the ignition or not.
Old 07-31-2008, 06:13 PM
I don't know Polygon. I know my 93 LeBaron convertible (base model with lots of options I guess) and my friend's 91 Dodge Dynasty both have this feature. If you open the driver's door while the key is in the ignition, and you press the power lock button, on either door, to *lock* the doors, it won't function, however you can still unlock them with the power lock button. I don't know much about this feature other than what I just typed, but I was assuming it was an EEK thing. However, you say you have an 89, which would mean you have the 80's boxy interior style. Perhaps this feature came out with the 90s "organic" interior style. Then again, the Dynasty never recieved an interior facelift... hmm a very good question you have asked... I am confuzzled.
BTW dpaswill, your problem sounds identical to what happened when the IOD fuse burned out on my Baron.
Old 09-08-2008, 11:53 AM
advancedpccenter advancedpccenter is offline
hey i have a 94 lebaron gtc and when i turn it on it sounds like one of the belts are squeaking. it gets louder as i press the gas pedall anyone know how to fix this?
Old 09-10-2008, 09:39 PM
Umm...wrong thread...?
