Old 07-10-2008, 05:03 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Rear axle weight rating?
I'm building a trailer using the old rear axle out of my '86 K-20 and need to know the weight rating. The RPO codes are long-gone with the glove box and dashboard, but it's the 14 bolt semi-floater. I'm not sure of the ring gear size, so I guess I'll measure it if the smaller isn't a high enough rating, if ring gear size even makes a difference.
And no, the sticker inside the door isn't readable
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-20-2008, 08:15 PM
72chevelleOhio 72chevelleOhio is offline
Re: Rear axle weight rating?
I believe the gvwr on my old 81 I had was 8400 lbs.
Same axle....if that helps..
Old 07-20-2008, 08:37 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
GVWR= gross vehicle weight registred, it's the weight of the truck. best i can tell, rear axle load for 2000 1500 silvie is 3300 lbs and pennies.
btw, you can recomposistion your leaf springs and increase payload by adding longer leaves. we, also, used to achieve this by adding spacers made out of tank rubber, between the lieves, to spread them apart. stiffens leaf springs and they can take more load. BUMPY!!
Old 07-23-2008, 07:40 AM
CrazyHorst CrazyHorst is offline
The payload capacity in a full-floating 14 bolt axle is around 5000 lbs...in other words, this is how much you can put in the bed of the truck.
Not sure how to derate for the semi-floater...I'd guess around 3500-4000 lbs. You could look up payload capacity for a new 3/4t truck...the pickup truck axles are essentially the same proven design repeated over many many years with some modifications for brakes, suspension brackets, etc.
IMHO truck-bed trailers suffer from being high-centered, and with fairly soft springs compared to purpose-built trailer axles which are stiffer, more compact, and lower. This is not to take away from your project but just an observation I've made over time.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
