Go Back   Automotive Forums Car Chat > Suzuki > Esteem
Old 07-10-2008, 03:50 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Esteem Front Struts - Bearings?
Had my daughter's 99 Esteem's wheels aligned and thought an up front rattling
upon hitting bumps was the steering mechanism.
Not so - Alton Tire's mechanic thinks it is the front Strut Bearings being worn.
I know not squat about what he speaks of.
Anyone ever worked on this car's front struts?
Is something I can safely do?
Never heard of Strut Bearings before!
DoctorBill
Old 07-10-2008, 11:59 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Esteem Front Struts - Bearings?
there are some manuals on e-bay for sale. will check tomorrow for bearing and upper mount
Old 07-11-2008, 12:06 AM
Crvett69's Avatar
ok, part you want is 905951 monroe, don't see it listed at shucks but a napa or someone else might be able to get it, thats the upper plate and bearing assembly. if you just want the bearing its 1043602 altrom
Old 10-31-2008, 10:03 PM
quick69gto quick69gto is offline
The upper strut plate, or mount, has a small bearing in it so the strut can pivot in the direction of steering. These can wear out so it's not uncommon to have them replaced when new struts are installed.
It is not something you can replace yourself in your driveway. It has to be done by a professional.
My suggestion is to have both front mounts replaced along with new struts. Your mechanic will have to take the struts apart anyway.
Good luck!
