power steering hose
Anyone ever replace the pressure hose? mine is starting to leak, i can see some seepage comming out from where the metal clamps are near the rubber part of the hose and a puddle forming on top of the steering box where the hose sits on, hence why its making a whine now when i turn. any special procedures doing this and will i need to completely refill the pump after?
2006 Chevy Cobalt LS |
Re: power steering hose
Your fluid will leak some while changing the hose. Make sure you have the proper wrenches and use a wrench on each side of the pump connection.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
ok sounds simple enough
