Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 07-10-2008, 08:53 AM
Flyers92 Flyers92 is offline
Wheel Bearing 2000 Protege
Wondering how to replace a wheel bearing on a 2000 Protege?
Old 07-10-2008, 01:06 PM
Doug Tatham Doug Tatham is offline
Re: Wheel Bearing 2000 Protege
It depends on if you want to replace the front or rear bearings. The front are very difficult and I generally have to heat it with a torch then press it out using a hydrolic bottle jack and a sleeve that I made myself (I don't have the special tools recommended for the job). The rear are a lot easier. The only thing difficult is removing the hub. The trick is to loosen the brake or emergency brake cable (I forget which).
Old 10-07-2008, 04:09 PM
New information. The hub assembly for the front comes with a wheel bearing installed. It runs about $100 on line. It's not to bad to install.
Old 10-07-2008, 04:11 PM
New information. The hub assembly for the front comes with a wheel bearing installed. Downside: They run about $100 each on line. It doesn't look too bad to install.
