Old 07-10-2008, 08:07 AM
onerchprk onerchprk is offline
Send a message via MSN to onerchprk Send a message via Yahoo to onerchprk
Question 97 Windstar Heater/AC Only blows on High
I have another problem i just found out.On my 97 the heater/ac control only blows on high.I thought it was the switch so i pulled the heater control switch out of my 96 winnie that worked fine and did a swap but it still only blows on high in my 97.I switched it back to my 96 and it works fine.Is there a resistor or a relay that i should check?This is one of the strangest things i have ever seen.Thanks.
1997 Aerostar (239,000 Miles)
1993 Aerostar (189,000 Miles)
Old 07-13-2008, 08:32 PM
Talking Re: 97 Windstar Heater/AC Only blows on High
Thanks tripletdaddy.It was the resistor box right under the glovebox by the blower motor...
Old 07-14-2008, 09:19 AM
tripletdaddy tripletdaddy is offline
Do you still have what I posted? Somehow the forum lost it. If you do, could you somehow get it back. Whatever you do, don't refresh it or it will be gone! What I posted is useful info for the next guy and I really, really don't want to retype it. I've already redone three!?! Urgghh
Old 07-14-2008, 02:22 PM
Thumbs up Re: 97 Windstar Heater/AC Only blows on High
Here it is
It sounds like your blower motor resistor has gone bad. It is located
on the evaporator housing(the coldest part of the black box under the
dash when the ac is on) under the dash on the right side. I want to say
it is under the glove box, next to a small light bulb (not sure if it
is exposed or not), a round metal can for operating one of the hvac
doors inside it, and to the left of a large section. It will have a 4
wire connector to it with wires black, red/orange, light blue/orange,
orange/black. It should be available at a parts store I'm pretty sure. If
you had no fan at all, then the relay would be suspect. Good luck.
