Old 07-09-2008, 10:36 PM
Joe Wilson Joe Wilson is offline
valve seals
I was wondering if anyone has installed valve stem seals and how you got them out and replaced them. Does it take a special tool? thanks
Old 07-10-2008, 06:00 AM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: valve seals
I used a high quality pair of duckbill pliers to get mine out and tapped the new ones in with a socket.
Old 07-10-2008, 11:55 AM
Re: valve seals
Thanks Johnny, I'll try that. I never tried to pull them out because I thought there might be a special tool to use for that. Just yank 'em out I guess.
Old 07-10-2008, 05:23 PM
91 ragtop 91 ragtop is offline
Re: valve seals
They can be stubborn and break in pieces before you get them all the way off so I took a flat screwdriver and heated the end with a torch till it was red and then bent the last 3/16-1/4 inch of it to a 90 degree angle so I could get under it and pull them out, Ken.
Old 07-10-2008, 07:35 PM
Re: valve seals
I had one that was stubborn and I used a 90 degree bent screwdriver on that one like 91 ragtop stated.
Old 07-17-2008, 08:22 PM
spy1309 spy1309 is offline
Re: valve seals
Are you burning oil? I changed mine only after the exhaust ones allow oil to get inside the cylinders.
