Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 07-09-2008, 09:25 PM
Raggaemon Raggaemon is offline
Replacing ac compressor 2002 Sable
I tried re-charging the ac unit but I noticed there was no vacuum at the low pressure valve and the compressor motor wasn't moving.
After trial and error I learned today that the ac compressor is not working and I will replace it.
Are there any special tools needed for the job?
Old 07-12-2008, 09:19 PM
reekor reekor is offline
Re: Replacing ac compressor 2002 Sable
Are you sure that you know what you are doing ?
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 08-01-2008, 08:37 PM
rhandwor rhandwor is offline
Basic hand tools,vacuum pump, gage set of hoses, new compressor,filter dryer, expansion valve or tube, filter dryer 3 or 4 cans of refergrant, compressor oil and leak tester.
This you may want to farm out.
Old 08-22-2008, 06:19 AM
Jrod7571 Jrod7571 is offline
I have a 98 sable and just replaced mine with just a by-pass pully, because the part is so expensive here in NY.
Their are 4 bolts that hold it in. you have to remove top and bottom hoses to get to the compressor. Also disconect a plug that go's to the compressor. once the compressor is free from bolts, belt and plug, you will need to have a friend to pry the motor back about 1 1/2" to 2" so that you can squeez the compressor out of the motor from up top. Good luck. it will take some time.
Old 08-22-2008, 06:32 AM
No special tools needed. Just siconect the battery and discharge the compressor system by pushing in the needle on the free-on intake nozzle. (its like deflating your car tires)
Then remove all tope hoses and bottom hoses so that you can get to the 4 long bolts that hold in the compressor. remove the belt from the pully and then unplug the sensore that should be pluged in under the compressor.
once the compressor is free, you will need a friend to pry back the motor about 2" so that you can squeez out the compressor from the top.
Goood luck
