Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-09-2008, 08:32 PM
navyboy85 navyboy85 is offline
Need Help
So i got a 96 gst and driving it home it spools up real nice but when i get on it a little the fuel/air meter shots to rich and the engine feels like its bogging out how can i fix the problum he told me it needs tuned so what should i do and how should i do it.
MHI Evo 3 16g (Ported + 34mm flapper),GT Manifold (Ported),GT 2G install kit,190lph Fuel Pump,Denso 550cc Fuel Injectors ,Injen Intake,K&N Filter,HKS SSQV BOV,SBR 2.5" S.S. with Dump O2 Housing (Ported),Full 5Zigen Exhaust,3in" Downpipe, short throw shifter, apexi 2 afc, big front mount intercooler. 12 psi boost.
Old 07-09-2008, 09:34 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Need Help
First off, is the guage a wideband or narrow band o2 sensor? If its a narrow band, I wouldnt take a lot of stock in it.
Secondly, what are you using for fuel adjustment? You cant simply toss in bigger injectors and exect the ECU to know, so you are going to be running quite rich. There's a few ways you can go about it, but for the newbie the best two options would be DSMlink or a SAFC variant + datatlogger.
The SAFC and datalogger is cheaper, but far more limited. The SAFC can only adjust fuel and can only support 650 cc injectors and even then its pushing it.
DSMlink is going to be a little more epensive, but its entirely worth the price. Not only can you datalog and adjust fuel like you can with the above combo, but there is a laundry list of other things you can do such as nitrous controls, no lift to shift, studderbox, antilag, etc. Its about $555 shipped new plus you'd need the EPROM ECU that goes for like $225. You can get the DSMlink and ECU package used for like $600 though if you shop around.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-09-2008, 10:05 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Thor for President
I vote that Thor gets voted number 1 pusher for DSMLink these days. That's all he talks about in every post. Go Thor!
But dido on what he said about the narrowband. And everything else for that matter.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-09-2008, 10:06 PM
Re: Need Help
well there is 550cc injectors and 190lph fuel pump but there nothing controlling it and im not sure if its wide band or narrow how can i tell all i know is theres a meter guage on the side that say lean moderate and rich and as soon as i push it the guage goes to really rich and the car starts to stutter is this bad for the car and could u give me some links for what i need or the name cause im not really sure of what your talking about is it just something for me to use to adjust the mixter so it runs smooth please explain.
Old 07-09-2008, 10:38 PM
david-b's Avatar
Dave is THAT guy
Re: Need Help
Sounds like a narrowband.
When your driving does it just rock back and forth like a semi-fantastic lights show at a Pink Floyd cover band without the contact high?
Throw it out the window next time your on the expressway and make sure something large and heavy, or a small car with a heavily fat person driving runs over it and buy a wideband. That's the only way you're going to know if you're really running rich or not. You also need something to control the fuel also.
75 Monte Carlo
Old 07-09-2008, 10:39 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: Need Help
maybe he is getting comission on every sale. lol
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 07-09-2008, 10:50 PM
Re: Need Help
yea it goes back and forth till i hit the gas then goes to read rich so i need to get a wide band whats the diffrence and what should i use to adjust the fuel and air mixer cause it only happens when i get on it and the turbo spools up then when i hit around 4500 rpm it starts to stutter. and slowly climb from there.
Old 07-09-2008, 11:12 PM
steviek's Avatar
steviek steviek is offline
Re: Need Help
now I agree with everything that everyone else has posted but I just wanted to note that narrowbands are supposed to read rich under wide open throttle. Unfortunately for you there is no knowing how rich is too rich. But I know what I can do !!!
ok stockers are 450s so your uncontrolled 550's make you 18% too rich. Add that in combination with the already very conservative stock dsm tune which is approximately 12-14% too rich and your got yourself one mean rich ass curve. Not to mention the 190 will be overrunning your stock fpr a little bit too but that is less noticeable under WOT. Yes your narrowband is garbage... I had one but gave it away when I realized how useless it was. All it is tapped into your front o2 voltage which goes to the ecu. So essentially all it is doing is measuring the voltage of a narrowband wire. ANd to make things even stupider the voltage is a max of one volt. Talk about a lot of info to be gained from that.
A wideband is its own entity. It removes your factory o2 sensor and sends a 5v signal to the display which converts it to an A:F ratio. THis is what you need to tune. In this "closed loop" system none of the information is going to or coming from the ecu. Therefore if you bypass the o2 then your car is inhibited on its own ability to learn and stabilize the ratio itself. Of course the rear o2 is less valuable then the front so that is the more common one that is removed. You may still receive a check engine light. However, instead of having your car essentially guess whether its too rich or too lean based on a narrowband output to the ecu you will have the ability to take charge with a tuning tool and the wideband enabling you to properly tune the car and eliminate guessing. Naturally the logger is so you don't have to have eyes in 10 places at once and can give you information which you cannot see or hear otherwise. That is why dsmlink is such a powerful tool as it can combine all these factors and enables you to fully control the innerworkings of your car.
Ps link pays me double what thor gets on commisions
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 07-09-2008, 11:24 PM
Thor06's Avatar
Jizzed In My Pants
Re: Need Help
Ha ha ha, you guys are silly. DSMlink is just a far superior tuning tool, that is unless you are running a track only car and already have a good concept of tuning. For 99% of DSMer's though, DSMlink is the clear answer. I almost dont know how I managed driving a DSM without it.
Old 07-10-2008, 06:01 AM
Re: Need Help
Can i use this to tune the car APEXI SAFC II</IMG> and is it alright to drive the car with out the tune till i can buy it or will it hurt the motor.
Old 07-10-2008, 07:38 AM
steviek's Avatar
Re: Need Help
Yes on 550's the safc2 will suffice. Thats the exact same tuning/injector/fuelpump combo I had a while back. It got me pretty deep into the 13's. Even without a wideband I can tell you that you need to subtract at least 18% fuel across the board once you get that installed. After that I wouldn't lean it out anymore until you get a wideband
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 07-10-2008, 07:39 AM
steviek's Avatar
Re: Need Help
yes your car will be fine without the tune. Running too rich is not as bad as too lean. the plugs will get fouled thats for sure but the engine is relatively quite safe.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 07-10-2008, 07:49 AM
Thor06's Avatar
Jizzed In My Pants
Re: Need Help
Not to mention your fuel economy is going to take a shit dive. I personally wouldnt do it, but I suppose you could if you had to.
Old 07-10-2008, 12:20 PM
steviek's Avatar
Re: Need Help
It is already on his car I believe. So I'm sure he knows about his economy
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 07-10-2008, 07:16 PM
Re: Need Help
Well guys i was changing out the brakes today and happen to want to look over the exhuast system and guess what there was a nice big hole where it rusted out i think this might have a big portion to why im running so rich what do u guys think about it. From the turbo to the cat is good no holes but after the cat its all messed up, and yes im going threw gas like its water should i still buy afc after i get the exhuast.
