Go Back   Automotive Forums Car Chat > Classic Cars
Classic Cars Do you just love the classics?
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-09-2008, 06:08 PM
BrianLas BrianLas is offline
1956 won't start
My '56 Chevy is not starting right now. I drove it Tuesday, and everything seemed fine. Thursday I tried to start it, it turned over, and fired, but didn't stay running. The next time I turned the key I got power to the dash and then nothing. No ticking no turning over, nothing, like when you try to start a manual without the clutch in.
Any ideas?
Old 07-09-2008, 06:55 PM
maxwedge maxwedge is offline
A990 racer
Re: 1956 won't start
Basic diagnostics here, **** Check for loose corroded battery cables. Got power to the starter solenoid when cranking? Check the battery capacity,
Old 01-29-2009, 10:31 PM
buddieboy buddieboy is offline
Any ideas?
go out to your car see if you can turn the motor over by hand ( battery disconected) turn it in the normal direction only if itmoves back but not forward then maybe your timeing chain has sliped because the gears shot ok
bewar if this is the situation your valves could become bent but most likeing the head studs would pullout off the head bosses making the valves loose by about 1/8 an inch if it has jumped time you must fix and line the timeing gears befor you attempt to crank the motor over so beware ,aside from that .. its some outher reason to get a haynes manual or visit your librarie read about diagnosing a no start or no crank it will guide you throughthe process
Old 01-30-2009, 04:10 PM
A990 racer
I know you are trying to be helpful, but check the dates before posting this is way to old, thanks.
Closed Thread
