Old 07-09-2008, 04:29 PM
3echo9 3echo9 is offline
Tire Wobble Check
Can anyone give me the possible component failure based on the tire play?
If the tire has play in it at 9-3 what are the possible problems and how would you test further?
Thanks.
2005 Chevy Equinox LT 186,000 mi
2004 Buick LeSabre 200,860 mi
2011 Infinity G37x 103,000 mi
Old 07-09-2008, 11:05 PM
fantastic's Avatar
fantastic fantastic is offline
Re: Tire Wobble Check
Could be a bad wheelhub/bearing Here's a link that should help... http://www.automotiveforums.com/vbul...hlight=bearing The link takes you to a post about checking the tire at 9-3 and 12-6 for any play. Hope it helps
Old 07-10-2008, 07:50 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Which car listed in your signature are you having problems with? And why are you running similar posts in two different forums? See link below.
http://www.automotiveforums.com/vbul...d.php?t=911667
Timeslip 08/12/06
AF Community Guidelines
Old 07-10-2008, 08:40 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
could be wheel bearing, most likely tie-rod/tie-rod end. (inner or outer)
Take it to an alignment shop, they won't align it, they'll tell you what needs to be replaced.
Just tell them you want it aligned, and that they need to get confirmation to replace/repair anything necessary... that way, if they do it anyway, without your confirmation, it's free... b/c they broke the law.
Old 07-10-2008, 09:44 PM
Both..the GP has just started to develop the same bounce in it. The buick has had this issue since I bought it with 108k but is much more pronounced.
Suspension work is pretty much the same in both vehicles. Are they not?
Thanks.
Old 07-11-2008, 04:58 AM
BNaylor's Avatar
Thanks.
Both vehicles?
I'll give you the benefit of the doubt on this one, otherwise one of the threads would be closed. However, in the future don't ever B.S. me.
Timeslip 08/12/06
