Old 07-09-2008, 02:16 PM
joevit joevit is offline
Tcc
I need to know where my TCC is located on my 92 GA sohc 4cyl. And how to replace it. Thank you.
Old 07-09-2008, 02:30 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Tcc
The toqrue converter clutch is located in the torque converter and the transaxle and engine must be seperated to service it. The solenoid can be replaced by removing the transaxle side cover. It's toward the front of the car and the top of the transaxle. It only takes a couple of hours to replace. Just a dozen or so bolts on the cover, a mount and bracket to remove and then a couple small screws that hold the solenoid in.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 07-09-2008, 08:59 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Tcc
Yeah here is a link that explains in great detail how to replace this.
http://autorepair.about.com/cs/doity.../aa011703b.htm
1999 Grand Am SS 3.4 OHV
