Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-09-2008, 12:04 PM
panheadbuck panheadbuck is offline
Shifter knob
I have a '99 Wrangler Sport and I got a new shifter knob from Quadratec. How does (or does it even) the shifter knob come off? I've tried unscrewing it and pulling it and it doesn't budge. Am I a wimp or am I doing something wrong? Thanks.
Old 08-04-2008, 11:22 AM
tomvid tomvid is offline
Re: Shifter knob
In my 97, The shifter knob screws off counterclockwise. Also, the "face" where it shows the shifting order, pops off and there is a nut on the end if the shifter arm.
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
