Old 07-09-2008, 11:12 AM
rex99 rex99 is offline
1994 Chevy Cavilier reverse flush
Hi All,
I would like to know how one can reverse flush the engine and radiator on a Chevy Cavilier 3.1L engine with air conditioning. Usually I'd look for the heater block hoses but I cannot seem to locate them on this engine.
Thanks
--j.c.
Old 07-14-2008, 07:02 PM
Blue Bowtie's Avatar
Registered Offender
Re: 1994 Chevy Cavilier reverse flush
You can remove the short bypass hose at the RF corner of the engine, remove the radiator cap, and flush from there.
Old 08-09-2008, 09:26 PM
Thanks....But I'm sort of in the fog. Is this the small perhaps 1/4 to 3/8 inch tube that goes to the top of the thermostat housing? Is there anywhere I can force in a greater amount of reverse flush fluid?
Thanks
--jc
Old 08-12-2008, 04:05 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Sorry, I'm a bit fuzzy here... don't remember which year they switched engines. If it's got the flat-ish topped intake manifold, remove the thermostat and use the upper rad hose. If it's the newer design with the 6 runners off the plenum, he means RF of the engine compartment which is actually the LF of the engine. There's a black pipe that runs along the valve cover, on the left side of the pipe (as you're standing in front of the car looking under the hood) is the hose, about 1" diameter, 6" long and bent into a sharp curve.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
