Old 07-09-2008, 11:28 AM
brivers brivers is offline
Foggy headlights
Just a simple fix for those foggy composite headlights. I had painted the roof of my car and was using rubbing compound on it and decided to try it on my headlights. Worked great. Only took about 3 or 4 minutes each. Been trying to make my car look a little more presentable lately. While I'm here does anyone know a good way to remove the glue from the pinstripes that I have peeled off. I have tried goof off, paint thinner, bug and tar remover, and laquer thinner. The laquer thinner worked the best but would break the glue down only temporarily and then it would start to smear. Anyone got a product that works?
Old 07-10-2008, 01:05 AM
leonbentz's Avatar
leonbentz leonbentz is offline
Send a message via Yahoo to leonbentz
Re: Foggy headlights
Wd-40
Old 07-10-2008, 10:05 AM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Just use a heat gun. How did you get the pinstripes off in the first place. Use a heat gun and if possible a razor blade. If you are very careful you can scrape just the glue and not hurt the paint. If you are re painting then it really won't matter.
Old 07-10-2008, 10:20 AM
Fatslicks Fatslicks is offline
I've known quite a few people to use lighter fluid to take decals off of their cars.
Old 07-10-2008, 10:41 AM
twinly01 twinly01 is offline
Smile Re: Foggy headlights
wow good job on the roof! Ya I'd try anything I knew wouldn't hurt the paint to get the vinyl off
