Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 07-09-2008, 10:16 AM
Franks97t-bird Franks97t-bird is offline
97 T-Bird brake proportioning valve
This part is no longer available from Ford and I cannot find a reman. Does anybody have any info on where to get one other that the junkyard. Of course a junkyard will do if that is all there is, but would rather not.ThanksFranks97T-Bird
Old 07-09-2008, 01:59 PM
Re: 97 T-Bird brake proportioning valve
Found one in a junkyard. Don't know if it works yet. Will post a follow-up as soon as I know.Franks97T-Bird
Old 07-09-2008, 05:59 PM
97Bird's Avatar
97Bird 97Bird is offline
Good luck finding the right one. If all else fails you could try an adjustable one. Ford Racing and many others sell them.
The Original 97Bird
Old 07-10-2008, 08:57 PM
Well the used one is worse than the original. Still looking. Anybody got any ideas?
Old 07-13-2008, 01:09 AM
marksatterfield marksatterfield is offline
I don't think this part was ever available.
I have the same issue, 1987 Thunderbird proportioning valve is leaking from the front nipple. It really doesn't make sense that the nipple is even visible.
A consideration is to buy a used proportioning valve from a junkyard for $10 and disassemble it to determine how it fits together. Then, replace all the O-Rings with nitrile rings from Harbor Freight where you can buy the whole pack for like $3.
This is probably going to be my approach when I do have to replace the unit.
--Mark
http://www.marksatterfield.com
--Mark
Old 07-14-2008, 05:56 AM
I have found a place that will rebuild the my valve and return it. It is Whitepost Restorations in Whitepost, Va. They mainly do full frame off restorations but also have a shop the rebuilds brake components.I will post when I find out how if it works or not. Frank
