Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-08-2008, 08:14 PM
rloya99 rloya99 is offline
1998 saturn
i have a 1998 saturn that the the check engine came we reset it and it come back with code p0172 system too rich (bank one) thank you for any help
Old 07-08-2008, 08:20 PM
RC1488 RC1488 is offline
Re: 1998 saturn
Replace your ECTS. 14.50 at the dealer. Code should go away within a week.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 07-08-2008, 09:38 PM
Re: 1998 saturn
thank you i will by that tomorrow would you mind tell me what that stands for (ECTS)
Old 07-08-2008, 09:45 PM
Cat Fuzz Cat Fuzz is offline
Re: 1998 saturn
This code indicates that the upstream O2 sensor is reading a rich exhaust condition. This could simply be a defective O2 sensor or something else could be wrong. The easy one to check would be the air cleaner. Make sure it's not plugged. You could replace the upstream O2 sensor since it is something that should be replaced regularly. At any rate, we would only be guessing here as it takes advanced diagnostics skills and tools to pinpoint exactly what is wrong.
Old 07-10-2008, 05:50 PM
Re: 1998 saturn
Disagree. I would say it can be replaced once every 100K if that. usually once a lifetime maybe twice.
Engine Coolant Temperature Sensor. This is used by the PCM to control many sub systems of the car including air fuel mixtures. When this sensor cracks (which yours is) the PCM makes the mixture rich, thus why your O2 sensor is detecting a rich mixture. Replace, reset the code with a scanner, diagnostic tool or remove the PCM B fuse fromt the underhood fuse box.
Old 07-15-2008, 07:30 AM
Re: 1998 saturn
okay i bought the sensor and the 02 sensor i reset the the light by removing the fuse it was okay for about and hour then ligth came on same thank you for the help
Old 07-15-2008, 07:31 AM
Re: 1998 saturn
Old 07-15-2008, 05:14 PM
Re: 1998 saturn
Did you check the connector for corrosion? Is it the same code? How new are the spark plugs?
I guess if neither is the issue then changing the O2 sensor in the manifold may be needed. However i dont really think thats the issue
