Old 07-07-2008, 09:42 PM
2500HD4x4's Avatar
2500HD4x4 2500HD4x4 is offline
AC causes low idle / stall
I'm driving my sister's car while she is in California since it gets twice the fuel mileage that my truck does. 1993 Toyota Celica GT with a manual transmission that runs great, except when the AC is turned on. Engaging the AC causes the car to idle very low (200-400 RPM), which pretty much stalls the car. If the AC is turned off, the RPMs jump back up to normal. I have posted this in the Toyota section, but there's not much activity over there and I assume the problem would be the same whether it's a car / truck of almost any make. Maybe the AC relay is not sending a signal to the computer to add more throttle when the AC is engaged? Seems like a simply fix, just can't put my hands on it right now. Thanks for any help, its nice to have AC in Georgia during the summer months.
1998 Silverado 2500HD
5.7L - 4x4 w/ Eaton Locking Diff
348,000 MILES
1993 Silverado 2500
449,000 MILES
Old 07-08-2008, 12:34 AM
2000CAYukon 2000CAYukon is offline
Re: AC causes low idle / stall
A buddy of mine had the same issue on a Camry (sp ?) and the shop I sent him to clean the TB and problem solved.
//2000CAYukon
Old 07-11-2008, 03:25 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I've seen that on a couple toyotas, the IAC being bad or carboned up will cause it too.... cleaning it is implied with cleaning the throttle body, but I just wanted to add that.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
