Old 07-07-2008, 08:57 AM
del2551 del2551 is offline
96 Sunfire Stalling
I have a 96 sunfire stalling when the car runs for more than an hour. Have changed out my coil pack and also ignition module. Not to mention also replaced the fuel pump. spark plug wires, and spark plugs. Installed a new fuel filter. And still no help. Does anybody out there have any suggestions on what this piece of junk needs to continue to run?
Old 07-08-2008, 09:11 AM
Spyder3K Spyder3K is offline
Send a message via AIM to Spyder3K Send a message via Yahoo to Spyder3K
Re: 96 Sunfire Stalling
Hey, what motor are you haulin' under the hood?
I'm wondering if your MAP sensor or your IAC sensor took a dump.
Old 07-08-2008, 11:44 AM
The motor in the sunfire is a 2.2 liter. Transmission is a automatic. I also forgot to mention that i have replaced the iac motor which was missing a screw and causing it to get stuck and also a bunch of build-up on it. Clean the throttle body also of build-up but still have the same problem. Need help as this is my only car before school starts again. Thanks for your input. I'll chk the map sensor and iac sensor. have a haynes manual to chk it out. thanks again.
Old 07-08-2008, 02:02 PM
Heh, don't worry about it, that's what we're all here for.
Make sure to let us know if it's the map or not. Even something as strange as the IAT, the coils being a little rusty on the electrodes (found that problem in a 2.2L Auto) could even make the engine run a little crappy. But now since the motor's been revealed, now we can get to the problem. lol
Old 07-09-2008, 01:20 AM
Jacfourteen Jacfourteen is offline
I was gonna ask what motor also, but then I saw "plug wires" and figured it must be the ohv b/c thats the only motor w/wires in 96.
99 Explorer (my daily driver)
-2" lift, 31" tires
-Magnaflow muffler
-7" Touch screen DVD stereo
-12" drop down LCD monitor
02 Mustang Convertible (wife's)
-K&N Filter
-Flowmaster 50
68 GMC (project)
-300 HP 350
Old 07-09-2008, 10:33 AM
Oh yeah, DUHYE... that's a pure example of how I lack common sense, hahahaha I don't have wires.
Oh man I think I just lost one I.Q. point on that!
Old 07-09-2008, 11:36 AM
i have checked out the map sensor and iac sensor they are good. Even went to a local junkyard and bought these and these were used to swap when the engine acted up. still the same. getting frustrated with this problem. Any help would be greatly appreciated. thanks for the previous input from other posts.
Old 07-09-2008, 07:18 PM
Since it only happens after the car has ran for a while I would suspect some type of electrical malfunction, Maybe when the component heats up enough the circuit opens and it stalls out, I would have guessed coil...but since you already changed that I guess not. Does the car start right back up, or is it just dead when this happens?
-2" lift, 31" tires
-Magnaflow muffler
-K&N Filter
-Flowmaster 50
68 GMC (project)
-300 HP 350
Old 07-11-2008, 09:43 AM
The electrical theory I'd support too. That's what my problem was. I'd start inspecting all secondary electrical equipment to see if you can find something out of whack.
1998 Chevrolet Cavalier Z24XR (My Baby)
1991 Toyota MR2
"When you turn your car on, does it return the favor?" -GM
"What just happened?!"
"You just pissed him off! That's what just happened!"
In the words of the Great Fred Baboo, if all else fails, "CHEESE IT."
Old 07-14-2008, 11:26 PM
Thanks for all the input and help. Finally figured it out. when i checked out the radiator hoses. upper radiator hose was really hot and then lower hose was cool to the touch. Changed out thermostat and noticed thermostat installed was 195degrees. oem calls for 180. changed out and cars runs w/ no probs. thanks again for everybodys input.
