Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 03-09-2003, 01:36 PM
zigen zigen is offline
Send a message via ICQ to zigen Send a message via AIM to zigen
My Headlight is Not Working. HELP!
Hey guys and girls I got a question hopefully someone might be able to help me with.
I just bought a '99 Civic HB and the right passenger side headlight bulb is not working. I have tried three different bulbs in the socket and none of them work. I have tried two H4 PIAA bulbs that worked in my previous '93 civic and I tried a plain stock bulb with no luck.
The corner bulb works but the headlight bulb does not.
Im thinking either the wiring is bad/cut or the bulb power harness is kaput.
In either case what can I expect to spend $$$ to fix this.
Before I make the expensive trip to a Honda dealer what are you guys oppionions on what the problem might be?
Old 03-09-2003, 01:48 PM
les6thboro les6thboro is offline
Send a message via AIM to les6thboro
check the fuses under the hood and under the dash
Old 03-09-2003, 04:34 PM
Thanks. I had competely forgotten about the fuses under the dash.
It must be the fuse because the high beam works and the low doesn't.
Now I just hope my bad luck will hold off long enough to put a new fuse in.
Old 03-24-2003, 05:09 AM
shepworldwide's Avatar
shepworldwide shepworldwide is offline
if it's not the fuse get a multimeter and test the wire for a connection
:twoguns:"shepworldwide":twoguns:
96 integra for sale or trade
huge northest meet may 31st. come check it out.
Old 03-24-2003, 09:01 AM
It did turn out to be a fuse. As a matter of fact the fuse for the low beam was missing so I just popped an extra fuse in there and all is well.
`94 Headlights not working...everything else does! help! pachecocar Corsica 1 04-28-2009 09:43 PM
HELP! 03 Imapala One headlight not working jsouth0623 Impala | Impala SS 2 04-01-2008 09:00 AM
1996 318i Headlights not working, HELP hero_harris 3 Series 1 05-02-2007 12:31 PM
Headlight not working right. cyvic Fiero 5 06-07-2005 02:37 PM
97 Taurus headlights not working help? ariesvamper Taurus | Taurus Wagon 4 11-13-2004 02:23 PM
