Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 07-06-2008, 07:45 PM
sweetmango sweetmango is offline
89 Suburban Shifting Hard
My 89 suburban seems to not want to shift up... it starts going just fine from a complete stop but when it is time to go to 2nd I can hear the enging rev... when I let off the gas and ease back into it that seems to make it shift... same with 3rd... I am thinking tranny problems but somebody mentioned that it could be a speed sensor or something? Please help...
Old 07-06-2008, 08:54 PM
Blue Bowtie's Avatar
Registered Offender
Re: 89 Suburban Shifting Hard
Sorry, not a speed sensor. You transmission is not electronically controlled like later versions. The only thing the ECM does for the transmission on your vehicle is to control torque converter lockup, which has nothing to do with your symptoms.
I'd verify the fluid level, check the Throttle Valve cable (TV) adjustment, and test line pressure in all ranges. Use a 300 PSI gauge connected to the test port on the left side of the trans housing.
Old 07-07-2008, 11:06 PM
Cool Re: 89 Suburban Shifting Hard
Thank you for your advise... but how do I check the TV adjustment?
Old 07-08-2008, 12:40 AM
2000CAYukon 2000CAYukon is offline
http://www.tciauto.com/Products/Inst...ble_adjust.htm
//2000CAYukon
Old 08-01-2008, 09:04 PM
Cusser's Avatar
Cusser Cusser is offline
Change the ATF, make sure it's the correct level. I had similar issue twice in my '88.
Old 08-03-2008, 07:55 AM
OleBones OleBones is offline
Sounds like a vacuum modulator on transmission to me. LOL, that is if this even has a vacuum modulator. If it does look on the tranny and you should see the modulator with a hose going to it. Pull the hose off and see if fluid is coming out of it. If fluid is coming out of it, it is bad and needs to be replaced. They can also go bad with no fluid coming out of them.
