Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-06-2008, 05:23 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Turn signal won't cancel
Well I had nothing better to do today so I pulled my steering column apart down to the ignition cylinder. Actually, I was going to change the cylinder but couldn't figure out how to get the screw out past the little plastic pc with the two copper strips that covers the screw holding in the cylinder. (I'm planning on re-keying the Caprice and my 89 & 92 trucks to the same keys so I don't have to have multiple sets of keys all the time) Now the RH turn signal won't cancel unless I manually move the switch. The LH signal works fine. I did find that the airbag wire was fouling on the signal switch while assembling everything, but I thought I had that sorted out before I installed the snap ring. Could that still be the problem, or do I need to go further into the column?
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 07-06-2008, 10:47 PM
Blue Bowtie's Avatar
Registered Offender
Re: Turn signal won't cancel
The turn signal switch uses two springs and a cam to cancel. The plastic cam also holds the horn sounder brush ring. The cam is seldom the problem, but may be worn or broken. Usually, you'll find a broken or improperly installed spring.
Old 07-07-2008, 07:14 PM
Thanks BB, I know about the springs as I had to replace one in one of my 73 Caprice ragtops that I had many years ago. But IIRC when the spring goes you have to hold the signal arm in place to actuate the signal. I don't have that problem; the arm stays up for the RH signal; it just won't cancel by itself. I'm wondering if there may be some slight adjustment to centre the turn signal switch because when I return the steering wheel to centre I can hear a very slight clicking sound from within the column. I'm wondering if the switch could be a hair off centre as I had removed it when I had everything apart. I have to take it apart again anyway as I found that the part of the cancel cam where the horn contact goes into was broken when I removed the airbag.
Old 07-08-2008, 08:02 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
The cam ears do break from manhandling the directional when forcing it to shut off while the wheel is turned. More than likely one of the 90 degree springs is out of place in your case, since you just had it apart. Most decent auto parts stores carry the springs.
Bob
Old 07-08-2008, 09:48 PM
Registered Offender
Or the dealership:
