Old 07-06-2008, 04:48 PM
Schooneys Schooneys is offline
97 Grand prix transmission fit
will a 98 transmission from a supercharged engine fit my 97 SE without the supercharger with any problems?
Old 07-06-2008, 05:09 PM
Highbeamz Highbeamz is offline
Re: 97 Grand prix transmission fit
It will bolt up, but the half shafts will need to be changed...or at least the driver's side, I'm sure someone can go into the specifics better than I, something about the HD transmission having different length half-shafts.
Old 07-06-2008, 05:15 PM
thanks for the response. found a detailed answer deep in the forum. will try to find the 4T60E.
Old 07-06-2008, 09:15 PM
wafrederick wafrederick is offline
Banned
Not true,you will not have to change axle shafts and I know the truth knowing I did a ton of these.Make sure the gear ratio is right or it will not work.All you have to change is the final drive if the gear ratio is not right and sometimes the electrical.
Old 07-06-2008, 11:05 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
I dont know guys, the 97 was offered with a 4t60e and a 4t65e. Better make sure what one you have before you try to swap in that 4t65e-hd from the 98 GTP.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-06-2008, 11:42 PM
Yeah, 97 is that oddball year...
Should it matter though? Wouldn't a Series II 3800 be a Series II 3800 regardless of year or was there major differences between the 4t60e and 4t65e? I know the 65 is a little beefed up compared to the 60, but I would think fitment wise it would bolt up...
2001 Pontiac Grand Prix GTP
14x,xxxkm's
Custom Cold Air Box w/ Airaid filter, Magnaflow Dual Tips, Quantum Tek 106 18" w/ Nexen N3000 rubber, Tinted Headlight Covers, Tinted Tails, Aeroforce Interceptor, 180* T-Stat, 2.5" ZZP Catted DP, Intense PCM, HID Conversion, F+R STB
Old 07-07-2008, 06:35 PM
its got the 4t60e trans in it
Old 07-07-2008, 09:31 PM
tblake's Avatar
In God We Trust
then the electrical connections will be different, and without further mods, the 4t65e-hd will not work.
