shes still broke
I have an 85 ta and I just changed the motor out for an upgrade. Finally got the motor running great and now the transmission started to grind when the clutch was engaged. Pulled the transmission and found my throwout bearing was shot. Replaced the throwout bearing and now the clutch wont disengage. When I start the car and put it in gear the tires start spinning. The tranny wont go into reverse even if the car is turned off. It feels like reverse is locked out. I tried bleeding the system but it doesnt appear to be doing anything. Someone please help I'm at wits end with this problem. Thanks.
Re: shes still broke
Welcome to AF.
All that comes to mind is a basic question. If your upgraded engine is not the one that originally came with the car, does it have a pilot bushing drilled and installed in the back of the crankshaft? Most SBC's do not as they were fitted to automatic transmissions. Without one, the clutch will not disengage. |
Actually everything worked as advertised until I had to pull the transmission for the throwout bearing after that is when this all started. It ran great prior to. I made some phone calls as well and everyone keeps telling me I just need to keep bleeding the clutch system. I'm lost. I'm tired of seeing her on jack stands and not being able to go anywhere. Any advice is appreciated. Thanks again
