Old 07-06-2008, 10:10 AM
metalbeast metalbeast is offline
Replacing the oil pump
I am in the middle of my head/ring replacement on my 93 Metro. I went ahead & bought a new water & oil pump. I was stupid & ended up ruining the gasket that came with the oil pump because I tried to prime the oil pump by putting oil in the thing. Oil got all over the gasket & ruined it.
I am going to have to make a new gasket ofcourse because you can't order it separate. MY QUESTION IS, IS IT NECESSARY TO RTV THE GASKET? I know this is a stupid question but I am use to SBC & SBFs that have different types of oil pumps. Thanks
1997 Camaro Z28 M6
1997 Mustang Cobra Build #6158
1991 Mustang GT M5
1993 Geo Metro LSi M5 (El Pollo!)
1995 Ford Ranger M5 (Ole' Bess, 311K )
http://musclecarevolution.com
Old 07-06-2008, 04:05 PM
91Caprice9c1 91Caprice9c1 is offline
Re: Replacing the oil pump
Do Not use RTV between the oil pump and block. a) A dry paper gasket is sufficient, and b) You do not want to run the risk of shooting dry RTV debris into your oiling system.
One time out of all the G10s I've rebuilt, I got a bad oil pump that spun freely off the engine, but bound up when mounted to the block. For your own good, rotate the engine w/o the pump on, then after you mount it and torque it down to make sure you don't get any binding issues.
-MechanicMatt
1996 Caprice 9c1 - Daily Driven Project Car
1993 Geo Metro - Accident
1991 Caprice 9c1 - Destroyed
Old 07-06-2008, 04:43 PM
-MechanicMatt
Wow! Thats got me worried. Was it a new pump or an old one? Thanks for the advice Matt! The gasket material I bought was a little bit thicker (Felpro Karropak). Will that still suffice?
BTW, I read someone filled their engine with 8 quarts of oil, disconnected the ignition & fuel pump & turned the engine over a few times to prime the pump. Any thoughts on that?
1997 Camaro Z28 M6
1991 Mustang GT M5
Old 07-06-2008, 05:06 PM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Just pull the coil wire and crank it over until the oil light on the dash goes out. I do that every oil change.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 07-17-2008, 07:30 AM
igya igya is offline
Every time, huh? Hum-m-m-m, seems a little over the top. Concerning the over filling with oil, not necessary. But, if on the other hand, if you just hate oil.......................go ahead!
