Is there any way to program keyless transmitter without going to dealer or locksmith?
Re: 96 Sebring Convertible how to program keyless transmitter
Try this:
Manual Programming Procedure (non scan tool) 1. Connect pin 1 of the 16-way data link connector to chassis ground or to pin 4 of the 16-way data link connector. 2. Close all doors, turn ignition key to off. 3. Turn ignition key to Accessory. 4. Turn ignition key to off, door locks will cycle once (in programming mode). 5. For each key FOB, press any button 3 times in a row to program code. When programming is complete, the door locks will cycle once. NOTE: IF A SECOND KEY FOB REQUIRES PROGRAMMING, IT MUST BE PROGRAMMED WITHIN 1 MINUTE OF THE FIRST FOB PROGRAMMING. PRESS ANY BUTTON ON THE SECOND FOB 3 TIMES TO PROGRAM ITS CODE. WHEN PROGRAMMING IS COMPLETE, THE DOOR LOCKS WILL CYCLE ONCE. 6. The programming mode finishes after the following: a. Programming of two key FOBS is completed. b. One minute has passed since programming. c. Pin 1 of 16-way data link connector is removed from ground connection. d. Ignition switch is turned on. e. Any of the doors are opened. |
i have the same car did that work
