Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 07-06-2008, 09:00 AM
Yogi_2864 Yogi_2864 is offline
Motor swap
Hey there folks I was wondering if a 2.7 from a 97 Intrepid would directly bolt in place into a 01 Intrepid? Would I have to change any sensors and ect from the 01 motor over to the 97 motor?
Thanks
Old 07-06-2008, 11:08 PM
AWP9521 AWP9521 is offline
Re: Motor swap
You need a 98 and later 2.7 L (24 valve SOHC) engine to swap into your 01. The 93-97 Intrepid base engine was a 3.3 L (12 Valve Pushrod) with an optional 3.5 L 24V engine.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 07-07-2008, 09:46 PM
Re: Motor swap
Oh maybe I got the year of the car the motor would be comming out of to go into my 01. But anyways as long as the year is 98 and up the motor will work and just bolt into place? Now also will any sensors need to be taken from the old motor and put on the replacement motor at all?
Thanks
Old 07-07-2008, 10:26 PM
Re: Motor swap
I would keep the old engine handy for possible sensor swaps, there may have been some minor changes between the years or no changes at all, but as a just in case measure yes swap over any sensor that doesn't fit into your 01 wiring connections. This may also apply to brackets for accessories and such too.
Old 07-10-2008, 10:17 PM
Re: Motor swap
Alright I will definetly do that. Thanks for your help
