Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 07-06-2008, 08:59 AM
jeff56755 jeff56755 is offline
95 Explorer check engine light
I have a 1995 explorer 4.0 and the check engine light comes on after you drive for about 5 mins.I have changed the thermostat and that didn't help.Has anybody got any answers?
Old 07-06-2008, 11:15 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 95 Explorer check engine light
Welcome to the forum!
There are hundreds, if not more, reasons the check engine light (CEL) could come on. You'll need to pull the diagnostic codes and post the specific code(s) here to get many reasonable suggestions to solve this issue.
Your Explorer is right on the borderline for the transition to OBD-II. Pretty much any parts store is able to read OBD-II codes for you at no charge. Some will also be willing to pull the EEC codes for you as well, but if not, you can do that on your own with a jumper wire or voltmeter.
The steps to pull pre-OBD-II codes can be found at the bottom of this page along with the available codes.
-Rod
