Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-06-2008, 08:09 AM
impalalover impalalover is offline
oil pressure/sending unit
Can anyone out there tell me where on an 05 3.4 impala the oil pressure/sending unit switch on the engine is located,i need to change as i changed my cluster from a base cluster to a gauge package and need to change the oil pressure switch to make the oil gauge work,thanks
Old 07-06-2008, 10:32 AM
maxwedge maxwedge is offline
A990 racer
Re: oil pressure/sending unit
Take a look to r/s of the oil filter?
Old 07-06-2008, 03:44 PM
ok. thanks,was looking at few areas but was'nt sure if it was the one by the oil filter or on the back of the engine,thanks,
Old 07-14-2008, 01:41 AM
HeMi101's Avatar
HeMi101 HeMi101 is offline
Send a message via AIM to HeMi101 Send a message via MSN to HeMi101 Send a message via Yahoo to HeMi101 Send a message via Skype™ to HeMi101
Just so you know, I looked into this further after I replied to your other thread about your cluster. The BCM is not involved, the Cluster reads right from the Class 2 Bus which I didn't know for sure. But you will still need to get the PCM edited by someone, or your self if you know how to reprogram one. The LA1 (base Engine) PCM isonly programmed to recognize 0 and 1 from the sender (whether the pressure is ok or not), not a value like the L36/L67 ones are. I don't think that would be too difficult though.
Old 07-14-2008, 10:56 AM
ok then thanks,so do i still have to change the oil pressure switch or just get the pcm reprogrammed?
Old 07-14-2008, 01:01 PM
HeMi101's Avatar
You still have to change the sender, the one thats in there is just like a switch. on if the pressure is ok, and off it its low.
Old 07-14-2008, 08:05 PM
ok is that your impala in the pic,if so mine is the identical color and car except i have tinted the windows ans put red enblems on there,how did you put the pic on here anyway
Old 07-15-2008, 12:50 AM
HeMi101's Avatar
My Avatar was just a PHotoshop of my car with the SS Tail Covers, But never did get them. The pic of my sig is one of the newer pictures of my car ya. You can add a sig or avatar by going to your "User CP" at the top.
And I also found my repair manual, and the Oil pressure switch should be right beside the Oil filter.
Old 07-15-2008, 04:32 AM
ok then thanks for all the info
Old 07-15-2008, 05:09 AM
i could'nt get a pic of car on here,
