Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-05-2008, 10:02 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Angry Melting Wastegate boost hose
Since I got my turbo on, I've been blowing through hoses connected from the WG to the inlet on the turbo. First hose were silicone based... melted from the heat from the engine bay. Now I was using some Menards hosing that I found for cheap. Short pieces were touching things and melting, so I took a long piece, wrapped the the WG around the the radiator where it was zip-tied. Was then ran along the radiator (not touching) to the inlet. That worked fine. I looked at it and it has a very small burn in it right by the compressor again. What does everyone else use? I have some -6an SS line that would probably fit and then clamp, but I'm sure there's got to be something else. Any ideas?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-06-2008, 09:00 AM
david-b's Avatar
Dave is THAT guy
Re: Melting Wastegate boost hose
bump... sorry but I need a fix! GHah!!!
75 Monte Carlo
Old 07-06-2008, 10:30 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
I just use silicone hose i got from extremePSI. It's very thick and in one of the hottest areas and still has held up fine.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
