Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 07-05-2008, 09:02 PM
vcorabi vcorabi is offline
do you have any tips to get better gas mileage?
99 Mustang GT 5speed
if I drive the car like a grandmom would I can get 300 miles to a tank.
I drive about 75 miles a day for work round trip and wanted to see how my car ranks with others and if there are any tips to help with gas economy?
I use the cruise control on the highway at 55 mph and rarely use the a/c.
I am thinking of trying the HHO gas install?
has anyone tried this and if so, results?
Old 07-09-2008, 03:57 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: do you have any tips to get better gas mileage?
The MOST I have got out of one take of gas was 357miles, and when I filled up, I put in 15.32gallons, so I was pretty much bone dry when I rolled in the gas station.
I average about 280~330miles per tank, and my car has some mods. If you want to increase your gas miles, remove some weight, the stock seats are about 140 together, aftermarket is about half that weight.
That stock steel drive shaft weighs a bit, so replace it with an aluminum or carbon fiber one.
The Flywheel is stupid heavy, replace that with a aluminum one.
I'm also using a electric water pump, saves gas since your not using the engine to power the pump.
I also went with a MOtive Gear Ax Series production lightened Ford 8.8 Ring & Pinion, which is lighter in weight due to the beveled back side of the Ring. That however is actually installed in my wife's car because it's 3.73's.
Get a fiberglass hood, save some weight over the heavy stock hood.
Swap to coil overs all the way around, drop some weight.
Get a tubular K-member, again, weight loss.
My ride at my site Silverstangs.
Old 07-15-2008, 11:46 AM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Aluminum or carbon fiber drive shaft, aluminum fly wheel, electric water pump,
lightened Ford 8.8 Ring & Pinion, fiberglass hood, coil overs, tubular K-member.
That looks like a lot of money just to get better gas mileage.
Old 07-15-2008, 11:47 AM
Start by determining your actual Miles Per Gallon
not miles per tank.
Then try all the usual things to improve your MPG.
Follow the recommended maintenance, keep your tires properly inflated,
reduce weight, don't drive aggressively, use the highest gear possible, use cruise control — selectively,
think clean, avoid excessive idling, roll up the windows, combine your errands, ect.
Old 07-30-2008, 11:24 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Don't use cruise control, that is a gas sucker....so I have heard
Draft when you can, its proven to increase milage by up to 30%
Coast to stop lights
Try not to use the brake pedal, any braking means less milage.
Slightly taller tires, ever inch taller is like dropping .15, so if you have 3.50 gears, they would go to a 3.35 roughly.
Drop weight like what was mentioned.
That is about it for now.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
