can some one please tell me the steps that are needed to remove and replace the front sway bar on a 2000 ls i looked through the forums but could not find it i just don't want to remove more than i need to i looks like it's kind of buried in there or maybe point me to the thread i just could not find it thanks
Re: LS front sway bar
Yeah, it's a bit of a chore to remove/replace. May I ask why you need to remove it?
The factory service manual details the procedure, but the text doesn't do a whole lot of good without the corresponding photos. If you'd like a PDF copy of the section, send me a private message with the request and an e-mail address for you that can accept PDF attachments. -Rod |
the bushings are shot and on the passenger side its almost gone so i thought just replace the bushings but after some reading you cant just replace the bushings and i think there to far gone to shim so the only thing that i think i can do is replace unless someone knows another way i am all ears thanks
What model LS do you have sport or non sport? You don't have to replace the whole sway bar just replace the bushings. I just had mines done. I have an 01 Sport and the size bushing needed is a 30mm. Now for the non sport models based on some researched I did I think uses 27mm. Click on the attached link http://www.energysuspension.com/pages/swaybbct.html. Trust me they work very well and you can grease them for periodically.
Thanks i tryed that link and no good i looked for a while and all that i could come up with is to replace the sway bar i can't find anybody that sells just the bushings and i have a 2000 sport if you know of anyone that sells just the bushings let me know or if you know who makes them thanks
I think what LeaSr77 was suggesting is that you can use the 30mm "Greasable Set # 9.5171" from the link provided. Don't order by application per se, but order a "universal" 30mm part for your Sport.
-Rod |
