Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-05-2008, 03:33 PM
chevysboy chevysboy is offline
Need Help
I have a 1994 Chevy Caprice Classic LS with a 4.3 V8 engine. The Odometer reading is 196,000. Only thing ever changed as long as I had this car was spark plugs,wires, and fuel pump. When I pull off it has a bad hesitation . On early mornings when I pull off it is ok for about 1 or 2 miles down the road. After that occurs thats when it starts the hesitation, and as it starts that I almost have to hold it to the floor to pick up speed. When I am at normal cruising at about 50 to 60 miles per hour thats when the hesitation also occurs even in a lower gear I still feel the hesitation. Need immediate help on what can be causing this.
Thanks, chevysboy
Old 07-05-2008, 03:50 PM
Blue Bowtie's Avatar
Registered Offender
Re: Need Help
If the Opti is the original unit, it might be time for a new cap and rotor. Plan on a water pump at the same time.
Old 07-06-2008, 01:02 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Need Help
and one thread usually does the work of 3 in your case!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-25-2008, 12:09 PM
fastfifty1 fastfifty1 is offline
Re: Need Help
have u checked your fuel filter that might be a cheap place to start
Old 07-25-2008, 09:59 PM
j cAT j cAT is offline
Re: Need Help
Thanks, chevysboy
if this engine starts ok and runs normally when cold then screws up after it heats up this is usually the EGR,,,,,this valve has a weak spring and is opening too much this will cause this issue....EGR is allowed to operate only after engine heats up....this part usually is in need of replacement after 100,ooomi...especially if operating in a hot climate...
