Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 07-05-2008, 09:03 AM
glc4122 glc4122 is offline
99 sunfire brakes
yes, i own a sunfire and having problems with brakes. the noise comes from front and back at different times. the noise sounds as if the calipers are stuck and after a little more pressure on pedal they release and make the noise.
Old 07-07-2008, 02:51 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
Re: 99 sunfire brakes
Is it disc brakes or drums in the back? I am guessing you have discs all the way around. I would pull the calipers off and check the pads. If the pads are worn just replace them. May want to replace the rotors at the same time. They may be binding up so be sure to pull the slide pins out and clean them off. Re grease with slide grease.
