Old 07-05-2008, 02:44 AM
1990teg 1990teg is offline
2000 ac problem
hey yall i have a 2000 cavi and am havin problems with the ac. I turn it on and the motor fan and everything kicks on and the motor bogs like usual but it blows warm air it won't cool off. i checked the refriderant pressure and it was reading 75psi and it shouldn't be over like 25. i believe something is up with the compressor. what do yall think and what would be the cheapest fix. gotta get the air goin gotta 5month old baby and not much money please help me. Thanks Jonathon
Old 07-05-2008, 09:10 AM
Blue Bowtie's Avatar
Registered Offender
Re: 2000 ac problem
Actually, the running pressure can be almost that high on the low side depending upon ambient temperature, heat transfer in the evaporator, and other factors. You really need to connect to both the low and high sides to perform any kind of diagnosis. The DIFFERENTIAL is what is important (for the most part).
Verify whether the compressor is actually running, turn the cabin fan on its lowest speed, and see if the low side pressure drops somewhat. Varying the heat transfer (by changing cabin fan speeds) should create a corresponding, albeit minor, change in low side pressure.
If the pressure remains high, the system may be overcharged, the compressor may be failing, the condenser may be clogging, or the expansion control may have a problem. In your case, I believe that is a simple orifice tube.
Old 07-05-2008, 08:20 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: 2000 ac problem
^^---- Qft!
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 07-08-2008, 09:10 AM
Spyder3K Spyder3K is offline
Send a message via AIM to Spyder3K Send a message via Yahoo to Spyder3K
Re: 2000 ac problem
Yeah Bowtie's right, haha Listen to him!
Old 07-16-2008, 12:40 PM
agco85 agco85 is offline
Re: 2000 ac problem
Hi,
I have the same problem with my 99 sunfire. Can you tell me where the orfice tube is located?
Old 07-16-2008, 02:16 PM
brcidd's Avatar
brcidd brcidd is offline
Re: 2000 ac problem
OT is at condenser outlet connection in front of passenger wheel-- number one failure mode in both cases is loss of refrigerant due to a leak-- most likely leak location is compressor case halves and the compressor shaft seal..both can be fixed..
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
