Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-04-2008, 06:04 PM
rebel_rose29456 rebel_rose29456 is offline
Cool 1995 Eclipse wont run
Eclipse (420a) Replaced all the sensors and the pcm. Checked all the wiring from each sensor all the way back to the pcm and everything is good. Checked the coil and its fine. Sometimes when you first turn the key to start it it fires like it wonts to run but will not do it. I checked the plugs for fire and have none. Good signal from the crank and cam sensors. Checked all the wires from the inj. all the way back to the pcm and its fine. I get a code 12 and 22 from the check engine light. PLEASE HELP ME
Old 07-06-2008, 10:12 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Re: 1995 Eclipse wont run
12 is your mass air flow sensor, remove/clean or replace
22 is your cranckshaft position sensor.
go here:
http://www.ebooksquad.com/2008/04/23...iagnostic.html
and download all the codes. be happy. i know from 94 that it won't start if MAF is disconnected.
Old 07-07-2008, 08:32 AM
the 1995 has no mass air flow sensor only a map sensor
Old 07-07-2008, 10:21 AM
ukrkoz's Avatar
same difference for his purpose, right? i am not the one who wrote the codes description. says MAF in the article.
i believe it's the large mesh inside the air intake, looks like french fries cutter. been some 7 yrs since i worked on those....
matter of fact, neither one of us is correct. it's mass air flow meter. but it does look like french fries cutter.
http://www.autopart.com/partsout/200...LIPSE/5128.htm
Old 07-07-2008, 10:39 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
The MAP is located in the intake manifold on the passenger side. It sit straight up with the connector facing towards the hood.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-07-2008, 11:17 AM
My eclipse is a 1995 420a 2.0 dohc and it dont have a mass flow sensor
Old 07-07-2008, 11:19 AM
david-b's Avatar
Dave is THAT guy
We know... if you're throwing a CEL for the MAS, it's referring to the MAP. It's practically the same thing, but measures the pressure instead of the actual flow. Same basic thing though.
75 Monte Carlo
every now and then when i turn the key to start the car it will almost start. Checked the ignition switch and it ohmed out bad so i replaced it and still wont run
Old 07-07-2008, 11:22 AM
but the map sensor ohmes out at what the book says it should be.
Old 07-07-2008, 12:35 PM
david-b's Avatar
Dave is THAT guy
Have you replaced with another ECU? Maybe the computer is going bad. Does it smell like burnt electronics at all? Pop off the cover and see if anything is fried. Try another one if you can find one.
75 Monte Carlo
Old 07-07-2008, 12:50 PM
bought a new one from auto computer exchange and got it wednesday. Still no luck
Old 07-07-2008, 12:52 PM
on the map sensor my book says that #2 on the plug is power and #1 is ground. On the plug when you check for power #1 is power and #2 is ground.
Old 07-12-2008, 07:10 PM
Changed the map and it still wont start. No fire at all
