Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-04-2008, 12:36 PM
chevysboy chevysboy is offline
hesitation problems
I have a 1994 Chevy Caprice Classic LS with a 4.3 V8 engine. The Odometer reading is 196,000. Only thing ever changed as long as I had this car was spark plugs,wires, and fuel pump. When I pull off it has a bad hesitation . On early mornings when I pull off it is ok for about 1 or 2 miles down the road. After that occurs thats when it starts the hesitation, and as it starts that I almost have to hold it to the floor to pick up speed. When I am at normal cruising at about 50 to 60 miles per hour thats when the hesitation also occurs even in a lower gear I still feel the hesitation. Need immediate help on what can be causing this.
Thanks, chevysboy
Old 07-04-2008, 01:16 PM
Musicman_fishing Musicman_fishing is offline
Re: hesitation problems
I had same problem. Get the cataletic converter checked out..
Old 07-04-2008, 02:59 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Does it overheat? If not, you can probably rule the cat out. Like I said before, it might be in the OptiSpark unit. Blue Bowtie knows more about this than I do, so I expect he might have something to offer if I am wrong.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-04-2008, 06:41 PM
j cAT j cAT is offline
Thanks, chevysboy
so this hesitation occurs after the engine warms.....this with your replacement part listing I would recommend the EGR valve for starters...this componet has a spring , the spring after years of heat and use will loose tension and cause the EGR to open too much.....this causes the hesitation after warm up as EGR will not be allowed operate when engine is cold.............usually these OEM EGR valves act up after 10years or 120,000mi...
