Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 07-04-2008, 11:09 AM
gobyslayer gobyslayer is offline
Code Reader Problem
When I hook my code reader up to the data link on my 2000 Bravada it tells me it's not conected. I have tried the reader on other vehicles and it works on them, any suggestions? Any help would be greatly appreciated.
Old 07-05-2008, 05:55 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Code Reader Problem
Are your other vehicles OBDII...1996 and newer?
Old 07-05-2008, 06:21 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
check for a good ground on pin five of the vehicle test port with a continuity meter. pin five is top row fifth from the left.
Old 07-05-2008, 06:37 PM
kayhanay kayhanay is offline
check your fuses, specially the ecm fuse.
Old 07-05-2008, 11:22 PM
Yes, my other vehicles are OBD II one was a 2000 Toyota Tundra and the other is a 2004 Dodge Ram3500. I will check the ground on pin #5 and also check fuse for ECM. If the ECM fuse is blown would the vehicle still run? Thanks for the advice, any other suggestions will still be appreciated.
Old 07-06-2008, 10:20 AM
Ground on pin #5 is strong, fuses appear to be good. Just to see if it was a GM compatable thing, connected it to an '02 LeSabre, works fine on it too. I am stumped, anyones ideas here would be appreciated.
Old 07-07-2008, 05:43 PM
ericn1300's Avatar
AF Premium User
you might try pulling the ECM unit and take it to AutoZone, a local speed shop, or a dealership to see if they can connect to it. If they can you have a wiring problem somewhere. If you have a local speed shop go there, they or the dealership might have a programing upgrade for you too.
Old 07-07-2008, 07:46 PM
why dont you try to check with your test light and see every pin on the connector and compare to the other cars. this way you know which pin is missing ground or power. if its missing ground just put a ground from the car to the wire.
Old 07-22-2008, 02:48 PM
nascar20 nascar20 is offline
The cigarette lighter fuse is tied into the obd port, mine was blown and would not read, was getting a not connected error, until I found the blown fuse.
Old 07-23-2008, 07:58 AM
AF - Advisor
Thanks for that tip nascar20....now if I can just remember that.
