Old 07-04-2008, 10:52 AM
cobra_im cobra_im is offline
Need Help BAD Clutch
I have a 1993 3000GT VR4
My break fluid resevoir keeps running dry, now my clutch isnt ingauging. are these tied together? A friend of my daughter said I need a new clutch I beleive this is some how tied into my hydralic system, where can I get this repaird, and do you think I need a new clutch as well? do you guys know what an estimated cost would be to repair this?
Please I am lost on this one.
Thanks
please email [email protected]
Old 07-04-2008, 01:06 PM
2old 2old is offline
Re: Need Help BAD Clutch
Your problem is the clutch can't engage (grab the gear) or disengage (press the clutch and allow it to free spin?)
The fluid reservoir being dry pretty much means you have a hydraulic leak from either the clutch master cylinder or slave cynlinder. Your clutch statement is confusing but I would look into fixing the master/slave cylinders first
Old 07-04-2008, 01:44 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Do you mean brake fluid resevoir or clutch fluid resevoir?
If that wasn't a typo, the brake fluid isn't connected to the clutch. If it is a typo and you meant clutch fluid, then yes, if that's dry you won't be able to use your clutch. Slave or master cylinder usually.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 07-06-2008, 10:19 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
I'm going to say thats a typo.
Look under the dash where the clutch pedal rod goes thru the firewall. If there is fluid dripping from there then the clutch master cylinder needs replaced.
If it is dry there look under the hood on the transmission next to the bellhousing. You will see the slave cylinder there. If it is wet below that the then slave is in need of replacement.
