Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-03-2008, 11:56 PM
chevysboy chevysboy is offline
caprice has hesitation
I have a 1994 Chevy Caprice Classic LS with a 4.3 V8 engine. The Odometer reading is 196,000. Only thing ever changed as long as I had this car was spark plugs,wires, and fuel pump. When I pull off it has a bad hesitation . On early mornings when I pull off it is ok for about 1 or 2 miles down the road. After that occurs thats when it starts the hesitation, and as it starts that I almost have to hold it to the floor to pick up speed. When I am at normal cruising at about 50 to 60 miles per hour thats when the hesitation also occurs even in a lower gear I still feel the hesitation. Need immediate help on what can be causing this.
Thanks, chevysboy
Old 07-04-2008, 02:48 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: caprice has hesitation
More Info.
It's like telling a doctor you have a pain but nothing else.
We cannot help unless you provide more info! What is your car? What engine? All that stuff is needed.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-04-2008, 12:03 PM
silicon212's Avatar
Confoundingly Lucid
Sounds like an Optispark failure.
BTW next time, it's easier for all followers of a thread if you just make another post with info instead of editing your first post. :P
