Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 07-03-2008, 06:14 PM
luxeryvic luxeryvic is offline
intake manifolds
i know that there are better heads than others for sbc's but are certain stock intake manifolds better than others?
Old 07-07-2008, 01:05 PM
MrPbody MrPbody is offline
AF -Advisor
Re: intake manifolds
Absolutely. There are far too many to make a complete "list" here.
General rules "of thumb": A non-EGR intake is better than most that ARE "EGR" (Exhaust Gas Recirculatioin, identified by a vacuum can and valve that "plumbs" exhaust gasses into the intake runners).
If you run a Q-Jet or other "spread bore" carb, always use a spread-bore intake, no adapters please. If using a Q-Jet, '68-'72 are the intakes of choice ('73 was the first year of EGR). The mid-'80s aluminum "spread bore" intakes aren't bad, but still have the EGR provision. Anything that "fits" fuel injection (TPI) will not accept a carb. TB (throttle body) intakes aren't much, either. "CrossFire" has been modified to make a ton of power, but be prepared for a LOT of work. Those are based on the late '60s "Smokey Ram".
The factory intakes from the mid '60s that are aluminum and mount a Holley or Carter AFB are superior in performance than any other single 4-bbl. intake factory-offered, provided the correct type carb is used.
If you have a specific casting in mind, let us know what it is and maybe we can dig up some info on it.
Jim
Old 07-08-2008, 08:34 AM
comp comp is offline
whats your combo ??
Old 07-08-2008, 11:26 AM
i plan on running a q-jet, i just have 2 manifolds and i want to know what one would be better to run on a 305 with a summit cam , i will post the casting numbers soon
Old 07-10-2008, 06:56 PM
ok here are the numbers
one is 14007376
and the other is 346249
what one is better/ will result in more power?
Old 07-10-2008, 07:18 PM
one is 14007376
both of those alum. ?
Old 07-11-2008, 07:28 AM
no, they are both cast iron 4bbl Q-jet manifolds
Old 07-11-2008, 12:14 PM
i'm not where my intakes are but you want alum.,, i'll find # later
Old 07-11-2008, 01:18 PM
i dont want to buy another one, i just have 2 cast iron intakes and i want to know which one is better so i can use the better one can anyone tell me which one is better?
Old 07-11-2008, 01:32 PM
maybe you can trade 2 for one
Old 07-11-2008, 02:41 PM
remembered i have a alum. one here i started porting ,, # is 14014432
Old 07-14-2008, 12:15 PM
what? u want to trade me your aluminum one for my 2 cast iron intakes?
might be kinda hard, im from ontario, canada
Old 07-14-2008, 12:18 PM
what? u want to trade me your aluminum one for my 2 cast iron ones?
Old 07-14-2008, 01:16 PM
AF -Advisor
Look at them. If one has EGR and the other doesn't, use the one that doesn't. If they're both with or without, choose the one in better condition. There won't be a significant performance difference, regardless.
Jim
Old 07-16-2008, 04:05 PM
no i got rid of all the iron one's ,,for alum.
