Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 07-03-2008, 12:20 PM
mrsseeoh mrsseeoh is offline
01 Chrysler Concorde PCM or TCM
Does anyone know if this vehicle has a seperate TCM (transmission control module) or is there only one PCM/ECM? My check engine light is on and giving diagnostic code P0605 (TCM ROM fault). Transmission is in "limp-in" mode and remains in 2nd gear. I replaced the output and input speed sensors. Same problem. I'm pretty sure I need to replace the TCM. My reading is indicating that this vehicle may not have a seperate TCM - just the one main control unit. Can anyone tell me if this is correct?
Secondly, can you tell me where in the engine compartment the TCM (or PCM/ECU) is located?
Old 07-05-2008, 08:04 PM
Re: 01 Chrysler Concorde PCM or TCM
Okay. I found out.
It does have a seperate PCM and TCM. Both are located just behind the headlight on the driver side. The TCM is smaller than the PCM.
Old 07-07-2008, 10:43 AM
jermanrat jermanrat is offline
Look for a pin pushout at the input and output sensor.
