Lumina APV Blower, No High
I'm having the opposite problem many others are having. My A/C blower will work on every speed except for High. Is this something I can solve by replacing the relays?
Re: Lumina APV Blower, No High
Yes check the high speed relay and socket
www.avigex.ca/xport/heaterrelay.jpg extensive use of max speed is detrimental to this relay and socket and motor. The 25 amps that flows at that time melts the contacts ; max speed should be used for short bursts only if max life is wanted.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. |
Is it possible to add a resistor on top to limit current. I am in texas and short bursts are not feasible. I change that relay like each 4 months, with maybe each year I have to redo the harness as well. Tired of it. Need a solution or a new car.
http://www.automotiveforums.com/vbul...9&postcount=18
~70k last 3 years with no major issues ~270k total; unknown prior history. |
Is there any part number?
Something like this on ebay. Should be able to get a generic one at any parts store. They are very common.
![]() ![]() http://shop.ebay.ca/?_from=R40&_trks...0A+Bosch+relay
~70k last 3 years with no major issues ~270k total; unknown prior history. Last edited by 96tsport; 08-24-2009 at 02:32 PM. |
Thanks for the pic, it is worth a 1000 words and only like $5. I am getting one.
Just wanted to point out the relay pix shows a 5 wire setup whereas the wiring diagram shows a 4 wire setup (in the same ad) ..so there are diff ones out there.
I believe the wiring in the car is a 5 wire setup ..so something to look out for.
